Non-orthogonality for FV method
Old   June 23, 2005, 05:01
Default Non-orthogonality for FV method
Michail
Dear friends
Please help with implementation of non-orhtogonality for finite-volume method for incompressible flows.
How to derive in non-orthogonal curvlinear coordinates:
- convective fluxes
- diffusion fluxes
- addition to the sourse term because of non-orthogonality from viscous terms.
Any links, course materials, lecture notes, articles in .ps/.pdf are very appreciated
Mike
Old   June 24, 2005, 10:10
Default Re: Non-orthogonality for FV method
andy
It depends on:
(1) what coordinates system you use to express the velocity/tensor components of your solution variables. Cartesian components are common but grid orientated components can have advantages.
(2) what coordinate system you use to express the spatial derivatives. For a structured grid this would usually be a coordinate system based on the grid because it is easy to evaluate.
(3) which independent coordinate directions you choose to decompose the vector/tensor components of the solution variables. This usually follows from (1) but with the occasional exception.
The most common choice is: (1) Cartesian, (2) grid orientated, (3) Cartesian. This is also perhaps the easiest since one can derive all the terms in the Navier-Stokes equations without needing to get to grips with coordinate systems and tensor analysis. All you need is the chain rule of differentation to expand the Cartesian spatial derivatives in terms of the grid coordinates and Cramers rule (or equivalent) to replace terms like di/dx with a combination of terms like dx/di which can be evaluated on the grid.
If I recall correctly, the Introduction to CFD VKI course notes of Anderson have a worked tutorial of the approach. This course ran for many years and the notes are widespread but I do not if they are on the internet.
Tom Pulliam's CFD course notes have the Jacobian flux matrices in the Appendices which you should find useful. These are on the internet somewhere. His 2D CFD code is freely available. I think his 3D code is only freely available to Americans but I could be wrong. Whatever, I am sure it is on his home page or somebodies homepage somewhere. He also wrote quite a good CFD book along with a couple of others which is available on the internet somewhere.
Can anybody firm up my wobbly references?
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
Comparison: Finite Volume Method vs. Analytic Method m-fry Main CFD Forum 1 April 20, 2010 14:40
Code for most powerfull FDV Method D.S.Nasan Main CFD Forum 6 September 4, 2008 02:08
Help about the preconditioner in gmres method Dan Gao Main CFD Forum 3 July 5, 2008 01:18
hess-smith method and fvm method yangqing FLUENT 0 March 20, 2002 19:25
