October 29, 2011, 22:50 |
Boundary Condition for DNS
Mike
Hi there,
I am simulating an incompressible turbulent wake flow (flow after a cylinder) by DNS, using implicit fractional step method. It is second order finite difference in a staggered grid. I am facing a problem: after some iterations (more than 40,000) wich is twice the time of traveling from the begining of my domain to the end, the code starts diverging. it is because some fluctuation in pressure are accumulated at the outflow boundary. I tried Neumann and convective outflow boucndary condition at the outflow plane for velocity and Neumann for pressure. Does any one know how to resolve the issue? I am almost sure it is because of the pressure boundary cindition. Thank you, saeedi |
October 29, 2011, 23:51 |
Al salamo Alikom
Safia
Hi
as I know that the finite difference is old method with regard to finite element or volume. why you did not try one of them? can I know which program you use to solve that problem ; for example, matlab or Fortran?? good luck |
October 30, 2011, 10:49 |
Mike
I am using energy conservative finite difference method wich is suitable for LES and DNS. I am using fortan in parallel environment which is parallelized with MPI and using a cluster coputer (super computer) to solve the problem. Thanks |
October 30, 2011, 20:52 |
could this help you
Safia
Hi again, I'm just inputting here citation from a book
6.3.1 OVERVIEW OF SETTING BOUNDARY CONDITIONS . . A practice that is widely adopted for inflow boundaries is to set the transported quantities of either a uniform or some predetermined profile over the boundary surface (Dirichlet). For outflow boundaries the convective derivative normal to the boundary face is set equal to zero; the transported quantities at the boundaries are extrapolated along the stream-wise direction of the fluid flow (Neumann). However, the use of such an approach is not as straightforward in some selected applications. Some difficulties may arise during the implementation of such boundary conditions. For example, nonphysical reflection of outgoing information back into the calculation domain (Giles, 1990) such as the fluid that may inadvertently re-enter the domain through these outflow boundaries as well as in regions of possible high swirl, large curvatures, or pressure gradients may significantly affect the convergence behavior of the iterative procedure. In addressing some of these difficulties, the specification of radial equilibrium of a pressure field is deemed to be more preferable than the usual constant static pressure for swirling flows at an outlet. Also, when strong pressure gradients are present, special nonreflecting boundary conditions are sometimes required for the inflow and outflow boundaries (Giles, 1990). from Computational Fluid Dynamics :A Practical Approach by Jiyuan |
October 30, 2011, 22:17 |
Mike
Assalamo alaykom,
Thanks. The book looks good. I will check it. |
October 30, 2011, 23:42 |
if you want the book just tell me
Safia
A.A.
I can give you link to download this book. it is about the CFD solvers such as ANSYS. Regards |
October 30, 2011, 23:48 |
Mike
That's kind of you.
Thank you |
October 31, 2011, 01:13 |
Here you are
Safia
Al salamo Alikom
I'm Phd student too. see below link now where the book is there.download it and keep it on your computer because it will not be available for long time due to copyright!!! http://ifile.it/vzwpyrn do not forget me from Al dua. before I leave see this this website can help you to get most books in pdf form, just register there and then input you requests ( you should follow the rules there). finally, can I see your code and do not scared from me because my reserach topic is deffernt. my research is about the 3D simulation of swirling flow!!!I seeked to conduct matlab code to solve my simulation in 3D and compressebale fluid!! However, you may find some thing for me Regards |
October 31, 2011, 12:44 |
Mike
Thanks for the link. I am sorry I am not allowed to release the source code. It is a collabration of group of PHDs and Postdocs. Good luck with your research. Mohammad |
November 6, 2011, 20:54 |
Shahram
Hi ,
I just read your discussion and as I have been working with DNS code, I faced with the same problm but on in outlet as I used NSCBC method in outlet. I have this reverse flow in inlet and it leads to convergence. Could you please let me know what kind of inlet boundary you used. Thanks Yours Shah |
November 7, 2011, 09:04 |
#11 |
Mike
Thanks for your comment. At the inlet I am just using simple Dirichlet B.C. BTW. I do not know what NSCBC is.? Could you give more info.? Thanks. |
May 18, 2012, 05:28 |
Centerline boundary conditon
#12 |
SAM
Hi guys
I am working on DNS in a pipe. I have a problem with the rms of radial and circumferential flactuation velocity near the centerline,i.e. see the figure. May anybody help me? Cheers |
May 23, 2012, 12:52 |
Characteristics or Riemann Invariants
#13 |
Patrick Godon
At the boundary, considering the velocity normal to the boundary, you have to write down the equations not for the primitive variables but for the characteristics of the flow (in one dimensional flows, these are the Riemann Invariants). The boundary conditions have to be imposed on the incoming characteristics, while the outgoing characteristics can be set to zero to avoid reflections of waves and numerical divergence.
see for example: Abarbanel, S., Don, W.S., Gottlieb D., Rudy, D.H., Townsend, J.C., 1991, Journal of Fluid Mechanic, 225, 557 Givoli, D. 1991, Journal of Computational Physics, 94, 1 Gottlieb, D., Gunzburger, M., Turkel, E., 1982, SIAM, J. Numer. Anal. 19, 671 This is possibly the best way to have non-reflective boundary conditions and it is the correct mathematical way to impose conditions on the boundaries. Let me know if you have problems findings these references, I could give you a direct link to something similar on which I worked. |
June 13, 2012, 18:44 |
#14 | |
If convective outflow boundary conditions are: du/dt +Uconv*du/dx=0 dv/dt +Uconv*dv/dx=0 where Uconv may be the mean velocity it should work !! so check your implementation. It is the best outflow BC ever found for incompressible flows. It avoids reflecting waves in the interior of domain and thus prevails from divergence of the code. here d/dt and d/dx stand for partial derivatives. |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Can anyone give me some hint on how to make traction free boundary condition? | poplar | OpenFOAM | 3 | January 14, 2015 02:37 |
Boundary Conditions | Thomas P. Abraham | Main CFD Forum | 20 | July 7, 2013 05:05 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
