Question about Continuous Adjoint Method
Old   October 31, 2011, 22:55
Default Question about Continuous Adjoint Method
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
I'm studying the "continuous" adjoint method by reading Dr.Soto's article
titled "ON THE COMPUTATION OF FLOW SENSITIVITIES FROM BOUNDARY
INTEGRALS".
http://www.scs.gmu.edu/~rlohner/page.../reno04adj.pdf
I have a question regarding this article. Could someone answer the
following question?
Q)Question about the derivation of the adjoint boundary conditions
My understanding is that the adjoint boundary conditions are derived so
that all the boundary terms of equation (13) are exactly canceled at all
boundaries. I think we need the value of δu and δp at boundaries when
deriving the conditions.
Could you tell me how to know these values?
It says in this article that "δu=0 on S and on the outflow (Γout)(δu is the
test function associated to the adjoint velocity, then it is zero wherever
ψu is prescribed)" but I can't understand the meaning of this description at
all.
Thanks.
fumiya is offline   Reply With Quote
Old   October 31, 2011, 23:26
Praveen. C
praveen is on a distinguished road
If on some part of boundary, u is fixed by the boundary condition, then du=0 on that part.
If u is not specified on some part S of boundary, and you have a term like
int(S)(X du)
then set X=0 on S. The idea is simply to get rid of all the variations in the primal quantities.
praveen is offline   Reply With Quote
Old   November 1, 2011, 00:50
fumiya's Avatar
Fumiya Nozaki
Thanks for reply. I understand your comment.
It says in this article that "δu=0 on S(solid boundaries to be optimized) and
on the outflow (Γout)". I think that δu=0 is valid on S because of the
dirichlet (no-slip) boundary condition but I can't understand why δu=0 on
the outlet boundary. I think dirichlet conditions are not imposed on the
velocity at the outlet when solving the flow.
Q) Is δu=0 valid on the outlet boundary?
I have another question.
Q) Could someone understand the meaning of the following statement?
"δu is the test function associated to the adjoint velocity, then it is zero
wherever ψu(adjoint velocity) is prescribed"
Old   November 1, 2011, 01:33
Praveen. C
Can you indicate page/paragraph in that paper about which you have the question ?
Old   November 1, 2011, 02:04
fumiya's Avatar
Fumiya Nozaki
Please look at the paragraph under the equation (19) on page three.
In this paragraph the adjoint boundary conditions are discussed.
Old   November 1, 2011, 02:41
Praveen. C
On outflow boundary, u must come from the solution, it is not prescribed. Hence we dont know du. So to get rid of du on outflow boundary, set Psi_u=0. Thats how I look at it.
Old   November 1, 2011, 10:09
fumiya's Avatar
Fumiya Nozaki
Could someone tell me why the following statement is valid?
Adjoint solver for flow problems jelmer OpenFOAM Running, Solving & CFD 11 March 12, 2017 06:52
Best front tracking method for surface evaporation Komkamol Main CFD Forum 0 July 17, 2009 10:23
SQP method for adjoint based aerodynamic shape optimization cfdbooks Main CFD Forum 2 May 26, 2009 10:40
Question about fractional step method Harish Main CFD Forum 2 September 25, 2006 09:29
A Question on VOF Method !!! CFDtoy Main CFD Forum 3 September 24, 2006 13:40
