Require the fluid properties of the following fluids at different temperatures
Old   October 21, 2010, 05:56
Default Require the fluid properties of the following fluids at different temperatures
rohitjvbibin
rohitjvbibin is on a distinguished road
I would like to require the thermal properties (density,specific heat,dynamic viscosity & thermal conductivity) at different temperature ranging between their freezing & boiling points of the following fluids listed below. This data is required for my M.TECH thesis.
1. ETHELENE GLYCOL
2. KEROSENE(RP 1)
3. ETHYL ALCOHOL
4. METHANE
(these fluids should be in their liquid state for this application)
Thanks in Advance
rohitjvbibin
rohitjvbibin is offline   Reply With Quote
non-newtonian fluid properties sara FLUENT 0 October 10, 2007 16:53
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Intl Conf Computational Methods in Fluid Power Jacek Stecki Main CFD Forum 0 November 10, 2002 05:49
Modeling of free surface in CFD ? Kim TaeMin Main CFD Forum 18 July 16, 2001 11:38
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 20:33
