how to set the boundery condition ?
Old   June 29, 2005, 02:58
Default how to set the boundery condition ?
Yun Heming
hi!I want to do a simulation for 2-dimention adverse-courrent heat exchanger by use the code-Fluent? but i don't know how to set the boundery condiontions.In the fluent help(user's guide),there are a few sentence to descript for it ,but see not clear,that is"Modeling Heat Transfer in Two Separated Fluid Regions
If your heat transfer application involves two fluid regions separated by a solid zone or a wall, as illustrated in Figure 11.2.2, you will need to define the problem with some care. Specifically:
You should not use outflow boundary conditions in either fluid.
You can establish separate fluid properties by selecting a different fluid material for each zone. (For species calculations, however, you can only select a single mixture material for the entire domain.)
" who can help me, thanks a lot !!!
Old   June 29, 2005, 09:08
Default Re: how to set the boundery condition ?
Andrew Hayes
have you tried looking on Fluent's webpage for any tutorials dealing with heat exchangers? I have done mixing problems using the species. I was able to completely separate the fluids by defining them as 100% in each of their respective areas of flows. So, I would have 100% of fluid A in flow channel 1 and 100% of fluid B in flow channel 2. I have never tried a heat exchanger that way though.
Thread Tools
Trackbacks are On
setting of level set method as initial condition sooroo3 FLUENT 3 January 7, 2015 20:15
set up the boundary condition by using star ccm+ layth CD-adapco 3 February 12, 2013 09:34
How to set the fixheatflux boundary condition LijieNPIC OpenFOAM 7 December 10, 2010 13:16
[UDF]a boundery condition duaiduaihu Fluent UDF and Scheme Programming 0 April 27, 2009 04:38
set boundary condition in Neutral file, in Gambit Vito Chow FLUENT 2 April 26, 2005 06:50
