June 29, 2005, 02:58 |
how to set the boundery condition ?
hi!I want to do a simulation for 2-dimention adverse-courrent heat exchanger by use the code-Fluent? but i don't know how to set the boundery condiontions.In the fluent help(user's guide),there are a few sentence to descript for it ,but see not clear,that is"Modeling Heat Transfer in Two Separated Fluid Regions
If your heat transfer application involves two fluid regions separated by a solid zone or a wall, as illustrated in Figure 11.2.2, you will need to define the problem with some care. Specifically: You should not use outflow boundary conditions in either fluid. You can establish separate fluid properties by selecting a different fluid material for each zone. (For species calculations, however, you can only select a single mixture material for the entire domain.) " who can help me, thanks a lot !!! |
June 29, 2005, 09:08 |
Re: how to set the boundery condition ?
have you tried looking on Fluent's webpage for any tutorials dealing with heat exchangers? I have done mixing problems using the species. I was able to completely separate the fluids by defining them as 100% in each of their respective areas of flows. So, I would have 100% of fluid A in flow channel 1 and 100% of fluid B in flow channel 2. I have never tried a heat exchanger that way though.
setting of level set method as initial condition | sooroo3 | FLUENT | 4 | July 31, 2018 04:20 |
set up the boundary condition by using star ccm+ | layth | Siemens | 3 | February 12, 2013 08:34 |
How to set the fixheatflux boundary condition | LijieNPIC | OpenFOAM | 7 | December 10, 2010 12:16 |
[UDF]a boundery condition | duaiduaihu | Fluent UDF and Scheme Programming | 0 | April 27, 2009 04:38 |
set boundary condition in Neutral file, in Gambit | Vito Chow | FLUENT | 2 | April 26, 2005 06:50 |
