November 11, 2011, 21:26 |
What will Reynold Number affect the fluid?
Rep Power: 14 |
We know the more viscosity the fluid has, the less it will be deformed by outer force.
Eg. Mercury has more viscosity than blood, and blood has more viscosity than water. However, Reynold Number is a dimensionless number. More Reynold Number will yield what effect on a fluid? |
November 12, 2011, 06:13 |
Reynold number is a ratio between viscous forces in your system and "inertial forces", this is what only matters in NS equation: flow with bigger momentum in the high viscousity fluid has same effect as flow with smaller momentum in a low viscousity system.
November 25, 2011, 21:44 |
#3 | |
AeroSuresh
Rep Power: 14 |
------------ AeroSuresh ------------ |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
