What will Reynold Number affect the fluid?
Old   November 11, 2011, 21:26
Default What will Reynold Number affect the fluid?
warlocklw is on a distinguished road
We know the more viscosity the fluid has, the less it will be deformed by outer force.
Eg. Mercury has more viscosity than blood, and blood has more viscosity than water.
However, Reynold Number is a dimensionless number. More Reynold Number will yield what effect on a fluid?
warlocklw is offline   Reply With Quote
Old   November 12, 2011, 06:13
truffaldino's Avatar
truffaldino is on a distinguished road
Reynold number is a ratio between viscous forces in your system and "inertial forces", this is what only matters in NS equation: flow with bigger momentum in the high viscousity fluid has same effect as flow with smaller momentum in a low viscousity system.
truffaldino is offline   Reply With Quote
Old   November 25, 2011, 21:44
Post
AeroSuresh
aero_suresh is on a distinguished road
As Re increases, it means that the Inertial force effects/influence is more for a particular type of fluid medium (viscosity = constant).
AeroSuresh
aero_suresh is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
