lift coefficient
Old   December 29, 2010, 06:07
Default lift coefficient
morteza08's Avatar
Morteza
morteza08 is on a distinguished road
Hi all
I wrote the vortex panel method code..
it gives me a very nice pressure distribution ...but i have problem in calculating lift coefficient..
i do this:
cpl= (cp at each point above airfoil) *abs( (x(i+1)-x(i)))
cpu= (cp at each point below airfoil) * abs((x(i+1)-x(i)))
cl=cpl-cpu
it gives unreal values fof cl.
the common shape of cl-alpha diagram is true..
but it goes up linearly to angle 55 then the stall occures. and the max cl is nearly 6..
any body can tell me the problem
here is that part of the code
i work on naca 23015
i read coordinate firstly for pressure side from TE to LE then coordinates from LE to TE for suction side
cpl=0
cpu=0
do i=1,m/2-1
cpl=cpl+cp(i)*abs((x(i+1)-x(i)))
end do
do i=m/2+1,m-1
cpu=cpu+cp(i)*abs(x(i+1)-x(i))
end do
print*,'cpu=',cpu,'cpl=',cpl
c_lift=cpl-cpu
morteza08 is offline   Reply With Quote
Old   November 23, 2011, 13:02
Shibin Mohamed
smab is on a distinguished road
DEAR morteza,
could you pls provide me with the settings in fluent for the same airfoil. I too work on NACA 23015. Its very urgent.
smab is offline   Reply With Quote
Old   November 23, 2011, 16:10
morteza08's Avatar
Morteza
Dear Friend
Although we are using the same airfoils, but the approachs are different. what are wreote above is aboute an old problem in a panel method code,
But i can not understand what you really want???
fluent settings while modelling an airefoil can be found here:
ask me if you have another question...
http://www.google.com/url?sa=t&rct=j...wKhOdQ&cad=rja
regards
morteza_a195@yahoo.com
Old   November 24, 2011, 04:39
truffaldino's Avatar
truffaldino is on a distinguished road
Originally Posted by morteza08 View Post
Hi all
Are you using panel method coupled with a boundary layer? I suppose you are not talking about inviscid panel methods, since stalling does not occur in inviscid flow. Anyway, to predict stalling your code should be a very complicated one taking into account flow separation/reattachment as well as transition to turbulence.
As for evaluating lift force in inviscid case, it is better to take a sum
Fy=sum cp(i)*(x(i+1)-x(i))
clockwise along whole contour and not separately for top and bottom, as for thick airfoils some LE panels which were at bottom at small aoa could go on top at big aoa.
In viscous case, you should add an y-component of tangential friction forces for each panel to the above pressure force.
truffaldino is offline   Reply With Quote
Old   November 24, 2011, 04:51
morteza08's Avatar
Morteza
dear truffaldino
At the time I wrote this post, I was working in an inviscid panel method.
But, after that I extended my work to couple the viscous effect to my code.
And It is already done...
Anyway, I thank you very much for your response....
Good luck
S.M.A
Iran
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
Zero Coefficient of Lift Problem MH FLUENT 0 February 25, 2007 11:48
Lift force or coefficient of lift Rola FLUENT 1 November 12, 2006 13:29
drag and lift coefficient Noé Siemens 5 July 13, 2004 10:21
Help needed - lift coefficient on front/rear axle Jan Jagrik FLUENT 0 September 21, 2000 10:21
