December 2, 2011, 11:44 |
Unable to generate surface mesh for a coil
Piti
Rep Power: 17 |
I'm using Workbench 11 and trying to mesh a coil with CFX-Mesh. When I click on Generate Surface Mesh, I receive an error message: Internal Error Unable to locate containing element for node Coordinate: 0.0000E+00, 1.5661E+02, 1.3248E+01 Coordinate: 3.3536E+00, 0.0000E+00 If I make a constant edge length smaller or try to refine spacings, it says: Internal Error MEM_EXTD storage allocation failed I'm not sure what these two messages mean. Can anyone explain to me what these mean and how to resolve this issue? I think my geometry is ok. Thanks, Piti |
December 2, 2011, 15:43 |
Andrew
Rep Power: 18 |
as a guess; it sounds like you have a floating node somewhere - maybe one of your lines extended too far and has a node at the end. Is there not a 'heal geometry' option or 'geometry check' that you can run?
The second error sounds like the mesh got too big for the amount of memory required. But, I am just guessing. good luck |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
How to generate the mesh on the surface in prostar | raymond | Siemens | 1 | September 13, 2001 05:48 |
