Optimize Vacuum-Cleaner-turbine
Old   July 20, 2005, 14:54
Default Optimize Vacuum-Cleaner-turbine
andreas
Hello
I am planning to build my third radiocontrolled vacuum cleaner. What is missing is the geometric data for the radial turbine. The first design was turbine without designed outlet from a commercial handheld battery vac with 70mm diameter, the second design was from a commercial fullsize vac with 110mm (but only one stage was used). The outlet i made of simple balsa stripes. Though the first design had a high speed and rather low efficiency, the second design was better, but the motor is running too slow. For the next design i would like to have something inbetween but i wonder how to get a more efficient design. How much would efficiency be increased if i optimized a turbine for a special set of parameters compared to a rough non-optimized "Try and Error" design? How exact must the input parameters be hit by the real design? How much is the efficiency reduced by parameter variation? Are there examples available on the net? Where can i find a good introduction on vac turbine design?
Thanks Andreas Strecker
Old   July 20, 2005, 19:25
Default Re: Optimize Vacuum-Cleaner-turbine
Mani
If I understand you right, you are talking about a compressor, not a turbine. I would suggest to get some fundamental knowledge about compressor design by reading a good book. It doesn't have to be specifically for vaccuum cleaners. There is a classical German text book by Walter Traupel "Thermische Turbomaschinen", which is quite old but still useful at least as an introduction to various concepts.
Problem with torque output from a turbine simulation. pa-dundas FLUENT 5 July 17, 2022 05:27
radiation modeling in vacuum mirko OpenFOAM Programming & Development 7 May 20, 2016 08:31
Assistance in Vacuum pump simulation enr_venkat CFX 5 November 20, 2012 11:50
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
turbine noise naser FLUENT 0 December 3, 2004 13:37
