Flow in cylinder
Old   December 18, 2011, 03:03
Question Flow in cylinder
SNH
nhosseini is on a distinguished road
Hi every body!
I want to solve a transient, incompressible inviscid flow in a cylinder, which its initial condition is zero velocity everywhere and at delta t=1 left boundary condition is V boundary= Vb and for right boundary condition we have pressure= ambient pressure
it seems that all nodes velocities should reach Vb after 1 time step but I have problem while using conservation methods, it takes some more steps for nodes to reach Vb.
I would be so thankfull if somebody could help me.
nhosseini is offline   Reply With Quote
Old   December 18, 2011, 10:39
Ford Prefect's Avatar
Ford Prefect is on a distinguished road
Originally Posted by nhosseini View Post
Hi every body!
What boundary condition do you have for pressure at the velocity inlet?
"Trying is the first step to failure." - Homer Simpson
Ford Prefect is offline   Reply With Quote
Old   December 18, 2011, 11:22
SNH
no boundary condition, I solve mass equation in inlet for pressure
Old   December 18, 2011, 15:23
What method do you use to couple velocity and pressure? Do you use some limited compressibility method or a fully incompressible method where div U = 0 ?
Is the behavior independent of time-step and Reynolds number (i.e. if you change dt or Re, will you reach Vb in the entire domain in fewer time-steps)?
Old   December 18, 2011, 22:21
SNH
I use a pressure based method, and yes its behavior is depends on delta t, by increasing time step it reaches the Vb in fewer steps. and by omitting transient term whole field velocity reaches to Vb in one step which is desired, thank you
Old   December 19, 2011, 03:45
Ok. I assume that you are solving some kind of Poisson equation for pressure and then you need a boundary condition for pressure at the inlet.
You state that you use continuity equation for this. Could you please show what you mean here?
Anyways, some methods specify a homogeneous Neumann condition for pressure at boundaries. However it might be better to use the normal momentum equation instead. By doing so you will compensate for grid size and time-step and the solution will be independent of the two. It will also converge within one time-step, given that your linear solver converges sufficiently.
Old   December 19, 2011, 04:51
SNH
first of all thanks for your quick reply, as I am really confused with it.
I solve du/dx=0 for mass and I use finite element control volume method, so I use u* and u* is pressure based and is
Mass: U*e - Uinlet = 0
u*e =( Ui+Ui+1)/2 + (Pi-Pi+1)/(2*ro*u*e)
U inlet = Vb
and
Momentum: U inlet = Vb
you mean that I need one more condition for pressure?
cylinder
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
1 Was FSI for a flow over a cylinder vmlxb6 CFX 17 May 16, 2011 02:29
Moving a Cylinder in cross flow after solving Dynamics equations of motion maruthamuthu_venkatraman OpenFOAM 1 November 19, 2009 13:55
Flow over a flat plate & Flow over a cylinder cfdxue Main CFD Forum 0 November 26, 2007 23:26
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
