Turbulence model for wing with deflected flap |
December 20, 2011, 02:03 |
sunti
Rep Power: 14 |
Dear all,
I need to run a simulation on a wing with a flap deflection of 30 degrees. The airplane is flying at 40 m/s at sea level. Would the k-omega SST be a good turbulence model to use for this case? Or would you suggest something else? Further, how do I estimate turbulence intensity and freestream viscosity ratio??? Any suggestions are welcome! Cheers! |
December 20, 2011, 04:37 |
I suppose you are talking about full-scale airplane, so that Re is of order 10^6-10^7. In this case the flow will be tubulent almost everywhere and you can use simpler turbulence models such as S-A model. Multi-equation transitional turbulence models shold be more accurate in theory, but in practice they are usually not without a sophisticated user input.
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Adding a Turbulence Model | doug | OpenFOAM Running, Solving & CFD | 11 | May 21, 2018 13:54 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
Fan heater model: what turbulence source to use? | andy20 | CFX | 7 | March 3, 2008 16:42 |
SSG Reynolds Turbulence Model | Georges | CFX | 1 | February 28, 2007 16:15 |
