Far field boudary conditions in FDM
Old   July 14, 2005, 16:29
Default Far field boudary conditions in FDM
James
I have a simple shear flow with complicated interface conditions and am struggling to formulate far field boundary conditions for a staggered type grid. Applying du/dx=dv/dx=0 on the boundary I still have an unknown pressure term outside my domain. Any ideas?
Also at the boundaries should I apply the boundary conditions above to the equations (Stokes) or simply disretise them and use them instead of the normal equations?
Thanks
James
Old   July 15, 2005, 12:19
Default Re: Far field boudary conditions in FDM
agg
This is for incompressible flow"
For velocities just set u(N) = u(N-1) {along X) v(N) = v(N-1) (along X)
For pressure set pressure such that pressure at boundary to be zero P(N+1) = - P(N-1) Where N+1 is pressure point just ouside of domain and N-1 is point just inside domain (for staggered grid)
Old   July 15, 2005, 12:47
james
Thanks, thats great.
One final thing, would you substitute u(N)=u(N-1) into the discretised Stokes equations (so that dp/dx=d2u/dy2 etc) or would you simply use u(N)=u(N-1) instead of the bulk equations?
Also do you know of any good books/sites on FDM and in particular staggered grid arrangements as on the whole I have found the literature average.
Thanks again
James
Old   July 20, 2005, 02:44
yuan
At outflow boundary the zero-gradient condition for (u,v,p) may work well. But you need fix something of the inflow.
Simple 2D airfoil Boudary Conditions doug OpenFOAM Running, Solving & CFD 3 November 9, 2009 10:32
Reading field values and setting them as boundary conditions sega OpenFOAM Running, Solving & CFD 1 July 7, 2009 06:18
What boudary conditions should I use lakeat OpenFOAM Running, Solving & CFD 3 February 12, 2008 03:20
computational MHD flows, boundary conditions packer Main CFD Forum 0 March 21, 2006 03:35
Far Field Boundary Conditions Xavi Main CFD Forum 8 December 17, 1998 08:11
