How to do Geometry from 3D mesh in ICEM
Old   August 2, 2005, 21:16
Default How to do Geometry from 3D mesh in ICEM
San24
Hi
Please, tell me how I can do geometry from ansys 3D mesh in ICEM.
I have 3D model of quarter my apparatus in ANSYS. Number of nodes and elements is maximum taking into account time of solution. I need to make model of full apparatus with about the same numbers elements and nodes or even smaller.
It would be great to make surface mesh on boudaries of 3D mesh. Then to do geomtry from surface mesh, to cut geometry by blocks, and mesh blocks with new desired grid.
ANSYS Mesh were imported to ICEM without problems.
I have found comand "Mesh-Facets" in menu EDIT
1.2.5: Mesh – Facets This option will convert unstructured mesh format into the faceted geometry data.
After it execution, i've got message "From current mesh, imported 0 surfaces, 0 curves, 0 points, 53 materials "
Some people tell me what this operation can be made in HyperMesh through one comand. But I haven't HM, and I heard it can be made by ICEM.
Old   August 2, 2005, 22:37
Default Re: How to do Geometry from 3D mesh in ICEM
Ahmed
It is almost impossible to advice on a problem without knowing the exact geometry and flow field. Can you use symmetry BC. on your quarter model? I hope this will help
Old   August 2, 2005, 22:57
San24
Unfortunately, I can't use symmetry BC, because i described my trouble with solid part of my model.
It will be Conjugate Heat Transfer. I have to make model with Solid part, and inside it will be fluid flow, but Fluid part haven't symmetry. Quarter model I have from ANSYS Termal-Stress analysis.
In common words, apparatus is Solid box, inside box is cavity with fluid, whete take place heat generation from unsymmetry located burners.
Old   August 3, 2005, 09:04
Myron
You first need to extract the surface mesh from the volume mesh. Do the Edit Mesh, Check Mesh functions for Uncovered Faces and Missing Internal Faces. For any problem areas it will ask for a new Family/Part for the new surface elements. Once you have those, you can do the Mesh-Facets command.
Old   August 8, 2005, 02:49
San24
Thanks very much. Its work.
Import Mesh from ICEM CFD to CFX Andre Almeida CFX 16 April 19, 2016 03:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 12:16
Icem mesh -> CAD geometry Ivan Main CFD Forum 3 August 13, 2006 09:38
