-   -   Two different methods for modeling a rotatory system (http://www.cfd-online.com/Forums/main/96189-two-different-methods-modeling-rotatory-system.html)
nav January 16, 2012 03:37
There are two possible methods for modeling a rotatory system (such as a water turbine),
1) using a moving mesh
2) fixing the blades, and rotating the housing employing an angular velocity boundary condition. (fixed grid)
It is clear that the second approach is much easier to implement. I wonder to know their differences? Do they both result in similar results?
Thank you very much,
Docfreezzzz January 18, 2012 12:33
Actually, if you are modelling an internal flow, you need both. You need to rotate the whole mesh (the rotor turning) and then apply a reverse rotation to the boundary (since the wall should be static). Otherwise the system will look static from the fluids point of view.
