Explicit converging faster compared to implicit
Old   January 20, 2012, 04:43
Default Explicit converging faster compared to implicit
C.Harish
harish_0689@ is on a distinguished road
Hello, can anyone tell me are there any cases where the explicit scheme converges faster compared to implicit, if so why does that happen?
harish_0689@ is offline   Reply With Quote
Old   January 20, 2012, 17:16
cfdnewbie
cfdnewbie is on a distinguished road
If the physical timestep is very small, i.e. close to the explicit time step, explicit schemes will be faster.
cfdnewbie is offline   Reply With Quote
Old   January 21, 2012, 04:14
C.Harish
Thanh for d reply cfdnewbie. Can u just eloborate it a bit more...also some of d example cases if u can...
Old   January 21, 2012, 10:58
cfdnewbie
it totally depends on your physics, your implementation and your hardware. It is not clear-cut, so there's no classical example. The smaller the timescales governing the flow, the larger your available number of cpus, the likelier the explicit scheme is to outperform the implicit one.
Old   January 22, 2012, 16:57
Ford Prefect's Avatar
Ford Prefect is on a distinguished road
Depends on what you mean with converge. Do you mean "convergence to steady state" or do you mean "convergence in the linear solver" or something else?
Explicit schemes are faster at each time-step since they do not need to solve a system of equations.
However, implicit schemes can take much larger time-steps. If you have implicit treatment of the non-linear terms then you also need some way to deal with this.
So basically:
Cheers!
"Trying is the first step to failure." - Homer Simpson
Ford Prefect is offline   Reply With Quote
Old   January 23, 2012, 07:00
C.Harish
i mean its convergence to the steady state.
Implicit versus Explicit Deepak Main CFD Forum 17 November 7, 2015 13:14
ddt explicit or implicit with courant number!! mrshb4 OpenFOAM 0 December 13, 2010 11:13
From Explicit to Implicit formulation emanuele FLUENT 2 October 4, 2006 14:17
Euler (explicit or implicit) anybody Main CFD Forum 2 May 8, 2006 02:12
implicit vs explicit pXYZ Main CFD Forum 2 April 21, 2006 09:48
