LES flamelet models
Old   August 4, 2005, 14:16
Default LES flamelet models
Simon Newbond
I want to know more about LES flamelet models.
In LES what value of the scalar dissipation rate should i use in the flamelet equations?
I have seen that some authors presume a shape of the scalar dissipation rate based on the mixture fraction, whilst others choose to use a 'conditional averged' scalar dissiation rate often averaged on assumed homogenous planes!!!
Also some authors use a sub-grid PDF for the sub-grid scalar dissipation rate (presumed lognormal) whilst others only use a PDF for the mixture fraction.
Can anyone please explain this subject to me. I dont really understand which dissipation rate i should use in LES - should i assume a homogenous direction? ... do i need a PDF for the dissipation rate? ... do i need to presume a form for the dissipation rate? ... etc.
Any comments would be welcome.
Old   August 5, 2005, 06:17
Default Re: LES flamelet models
RR
i have seen that Pitsch uses an unsteady flamelet model and a conditional average of the scalar dissipation rate (x). also cook uses a presumed form for x and a lognormal distibution. but i dont know which approach is more valid or which one is best to use.
anyone else any ideas?
LES and DES models for wind turbine mohammad Main CFD Forum 6 April 30, 2011 22:01
A bug in using dynamic LES models arslantuf OpenFOAM Bugs 6 December 8, 2009 16:34
LES models: Jonathan Lemay CFX 6 March 3, 2008 06:51
unsteady flamelet models dean Main CFD Forum 2 October 5, 2005 19:22
Numerical Implementation of LES Wall models dragon Main CFD Forum 2 March 14, 2005 00:53
