January 21, 2012, 12:07 |
Minimum Allowable Wall Distance
I setup a model in starccm+. I get a warning "wall distance limited in n cells". I ran the simulation anyway and my solution seems to converge nicely. The residuals all decrease. I read in the manual that if you get that warning about wall distance, you should remedy it. So I tried reducing the minimum allowable wall distance so that less cells are limited. Now my turbulent residuals and energy residuals seem to be oscillating, though the other physical parameters that I'm monitoring in my solution still seem to converge correctly. So does it matter if a small number of my cells have their wall distance limited (~1,000 in a 6.5 million cell mesh)?
January 21, 2012, 12:11 |
cfdnewbie
Rep Power: 20 |
are you doing RANS?
January 21, 2012, 12:16 |
yes, it is RANS
January 21, 2012, 12:21 |
cfdnewbie
Rep Power: 20 |
what kind of model are you using then?
January 21, 2012, 12:26 |
It is a steady simulation using segregated flow and segregated energy equations. My turbulence model is realizable k-epsilon two layer with all y+ wall treatment.
January 27, 2012, 13:58 |
Okay, so after some time, I found out another difference between these two times I ran this case. The first time, my mesh had 2 prism layers adjacent the walls in the model. The second time, I somehow (accidently) used a different outdated mesh that did not have prism layers included. The absence of the prism layers seems to cause the funny behavior in the residuals. But despite the residual behavior, the actual physical solution parameters (flow velocity and temperature) does not seem to change between using a prism layer and not using a prism layer (for my modeling scenario, anyway).
June 16, 2012, 16:18 |
warning
David L
I have this warning " wall distance limited to 1e-6 in 678640 cells in region A" ... What can I do?
June 16, 2012, 16:39 |
You can change the minimum allowable wall thickness (reduce it) and not as many cells should be limited. Does it cause you a problem or does your simulation still converge?
minimum allowable, wall distance |
UDF: Distance from the wall | Gabor | FLUENT | 6 | May 24, 2018 08:27 |
calculate distance from wall to neighbourig cell centroid | rr123 | Fluent UDF and Scheme Programming | 39 | March 14, 2017 02:41 |
wall layer distance in ICEM HEXA | F.K. | CFX | 0 | November 3, 2004 04:48 |
Distance to the nearest wall... | Michal | FLUENT | 6 | February 13, 2001 15:49 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 02:16 |
