Negative Jacobian
Old   July 27, 2006, 16:31
Default Negative Jacobian
PC
I wonder if you can help me here. I have created a body-fitted mesh inside a circular nozzle where I have some negative jacobians, I dont undertand how I can remove these negative jacobian. These happens if I increase the mesh points.
Thanks in advance
Old   July 27, 2006, 16:42
Default Re: Negative Jacobian
Renato.
You can work out it by changing the nodal connectivity of the negative elements, e.g.:
A triangle with nodes i, j, k can be described by:
i-j-k or i-k-j
one will have positive Jacobian while the other will have negative. You only need to set the nodal mapping accordingly. In finite element method this ordering is usually counter-clockwise for positive Jacobians.
ps: It can also be due distorted/invalid elements
Cheers
Renato.
Old   July 28, 2006, 01:19
Dr.Nick
Renato's right. it depends on the vector product and normal, i.e. say Normal=(V1xV2), angle(Normal,i)=+R1. Hence, Normal=(V2xV1), angle(Normal,i)=-R1; where i={1,0,0}
Old   July 28, 2006, 08:59
Arambatzis George
I am also writing a 3D code using tetrahedrals. My problem is that some elements have negative Jacobian.
Have you any ideas to solve this prolem? Or any books or lecture notes or links?
Old   July 28, 2006, 10:16
Renato.
Your problem can be solved in the same way described previously. For a tetrahedra formed by i-j-k-l nodes you might have the following conectivities:
(assuming FEM standard mapping) I-J-K-L = positive Jacobian I-K-J-L = negative Jacobian
You can use the following piece of Fortran code to compute the element volume (x6) V6 = x21*(z31*y14-y31*z14) + x31*(z12*y14-y12*z14) + x41*(z12*y31-y12*z31)
where: xij = xi - xj (regarding the nodal coordinates)
Regards
Renato.
Old   July 28, 2006, 10:31
Default Re: Negative Jacobian (NOTE)
Renato.
I should have also emphasized that negative Jacobians can be due to distorted and invalid elements!!! In this cases, you can't do anything else remeshing your model or fixing the bad elements locally (usually made by hand, picking and moving nodes). Another possibility can be some float point problem related to nodal coordinates. You can always be facing the range the machine number representation -- usually IEEE for PCs (*). In this case, changing the scale of your model can helpful.
Mesh problems usually happen when you import/export your model through several softwares due to loss of accuracy when representing the model entities (nodes, edges, faces, etc...).
Regards
Renato.
(*) (unfortunately or fortunately) computers have limited floating point representation.
Old   July 28, 2006, 12:46
Mani
if you get negative Jacobians in "some" cells of your structured grid, it will hardly be a problem of coordinate orientation.
the fact that it happens only with fine grids suggests small inaccuracies in your grid that lead to cross-overs at small cells, maybe related to floating point precision, or simply incomplete convergence of your grid generator. you should inspect the grid.
Old   July 30, 2006, 05:44
R Andom.
If all your jacobians are negative, then you are fine also.
Old   January 22, 2012, 14:34
Vijayendra is on a distinguished road
Originally Posted by Renato.
;44158
i-j-k or i-k-j
Cheers
Renato.
I found this message regarding the naegative Jacobian helpful as I also have a similar problem. I have the following question regarding the triangular elements:
Considering i-j k if I get negative jacobian, I considered i-k-j. In most of the cases it did work. But in few cases, even this did not work. In that case, I just permutated like:
1-2-3
1-3-2
2-1-3
2-3-1
3-1-2
3-2-1
one of the permutation did give a positive jacobian. Can I consider this permutation and proceed with the further calculation?
Any clarification will be highly appreciated.
Thanking you in advance
Vijayendra
Vijayendra is offline   Reply With Quote
negative element volume (CFX-10.0) CFDworker CFX 8 September 27, 2011 18:16
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
blockMesh error ... balkrishna OpenFOAM Pre-Processing 0 August 17, 2010 02:39
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
