Light Post
Old   August 16, 2005, 10:18
Default Light Post
fj
Hello... I have not much experience with CFD and I do not know if is really necessary to use it in my problem. I need to estimate the stresses in a light post, the velocity of the wind is about 150 kph. I know also the conditions of humidity and dry bulb of the wind. In fact, I really do not know how to estimate the boundary conditions in the structural problem (without modelling the F-S interaction). Do I need to use ideal gas eq to estimate the mass and then to integrate the velocity in a lapse of time in order to calculate the force? (F= m dv/dt) I know that a good model of FSI could solve my problem, but I have no much time to explore it, but I want to estimate the stresses in a first hand in a simple structural model, without fluid. Maybe later if I have time, I will spend a little in a FSI model. I have experience with ansys. Thank you in advance! frank
Old   August 16, 2005, 11:19
Default Re: Light Post
Jim_Park
I'd start by looking the cross-section of the post, which (I guess) is circular. Flow over a circular cylinder has been studied a lot. For a classic book with lots of data and photos, see Schlichting, Boundary Layer Theory. Probably any edition will do. The objective is to ESTIMATE the force from the drag coefficients tabulated for this flow.
First I'd determine if the conditions are right for vortex shedding from the post. That would result in period forcing of the post, which would I think result in a periodic boundary condition on your structural analysis. Without forcing, you still have to deal with any variation in your wind velocity.
Is it possible that you don't need detailed wind forces, just an overall force vs. time that can be imposed on the post model in your sress analysis? I'd guess yes.
Please note the liberal use of the word 'guess' above. Perhaps this will give you a place to start thinking about the problem?
Old   August 17, 2005, 10:41
fj
Thank you Jim your advice was really useful.
Ansys Post processing ano999 ANSYS 1 May 27, 2011 16:24
NO model vs post processing in coal combustion,CFX sakalido CFX 1 April 15, 2011 14:07
Proper output of angle of attack in CFX post Kevin CFX 3 October 18, 2006 12:18
Light Angle in Post Rui CFX 2 October 11, 2005 07:43
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
