simulation naca 2d
Old   February 13, 2012, 18:25
Default simulation naca 2d
Abdelkader
Abdelkader_Aero is on a distinguished road
Send a message via Skype™ to Abdelkader_Aero
hello for everyone
i simulated an airfoil naca 633618 2D in ANSYS fluent with raynolds 9 e5 i used the turbulence model Spalart Allmaras , when i keep the solution methode as default (schem(simple),momuntium (first ordre)) i get some result of CD greater than or duble when i use the same parametre with changing the momuntum to seconde order.
the value of y+ is varie etwin .05 and 0.95
can the anyone help me to choose the rigt solution methode
thank you in advance
Abdelkader_Aero is offline   Reply With Quote
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
NACA 2412 airfoil simulation using Turbulence Models mahbub03 Main CFD Forum 0 February 1, 2011 12:48
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 08:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 18:57
NACA 0012 simulation results Luis FLUENT 3 February 15, 2006 11:42
