emptying liquid from spinning circular tube
Old   July 2, 1999, 10:26
Default emptying liquid from spinning circular tube
uvce
I have a circular tube which is spinning at a particular RPM. The center of spinning is the center of ring tube. The hallow tube is full of liquid. If a small hole is made at one point in the tube, how to calculate the time required to empty the liquid from the tube using CFD?
Condensation of refrigerant inside the circular tube vishalpatil FLUENT 2 May 2, 2011 04:31
liquid temperature at tube outlet? phsieh2005 Main CFD Forum 0 October 11, 2010 20:33
Heat transfer in circular tube with constant wall heat flux ali radwan ANSYS 0 August 30, 2010 20:30
liquid piston in horizontal tube Allen_Lin FLUENT 0 May 30, 2009 03:47
liquid film thickness over spinning disk fadhil FLUENT 0 May 28, 2008 07:10
