Home > Forums > Software User Forums > COMSOL
Solving from 'boat' viewing from 'shore'
Old   February 25, 2012, 02:44
Default Solving from 'boat' viewing from 'shore'
s Kumar
doctsh is on a distinguished road
Hi friends!
I have solved a simple 2D time dependent CFD simulation using direct solver in COMSOL. I have used fixed mesh method (body-fitted reference frame) so that mesh movement does not cause any problem. After solving I want to view (from the fixed frame of reference) the solution as if there is mesh movement as in the case of moving mesh. Is it possible?
Thanks in advance
Doctsh
doctsh is offline   Reply With Quote
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
