Farfield BC: vortex correction for lifting bodies |
August 30, 2005, 11:17 |
i'm reading Blazek's CFD book and he said that for the farfield BC of lifting bodies, some corrections have to be made, namely in 2D, u(inf)(new) = u(inf) + (tau*sqrt(1-M(inf)^2)/2*pi*d)*sin(theta)/(1-M(inf)^2* (sin(theta-alpha))^2) v(inf)(new) = v(inf) + (tau*sqrt(1-M(inf)^2)/2*pi*d)*cos(theta)/(1-M(inf)^2* (sin(theta-alpha))^2) tau is circulation, (d,theta) are polar coordinates of farfield, M(inf) is freestream mach no. I would like to check if I can apply this to incompressible NS eqns. I'm using the fractional-step btw. Moreover, is this helpful in incompressible flow? It's stated that the farfield radius can be reduced by an order of magnitude when used. please comment. thanks! |
August 30, 2005, 22:52 |
Re: Farfield BC: vortex correction for lifting bod
This correction can be applied for lifting flows. Hence it is most appropriate for subsonic flows but might also help for transonic flows. For imcompressible flow, I think it is enough to put M(inf)=0 in those formulae. Also see the following reference
MD Salas JL Thomas, Far-Field Boundary Conditions for Transonic Lifting Solutions to the Euler Equations, AIAA Journal, vol. 24, no. 7, 1986 |
September 6, 2005, 02:10 |
ok thanks. but has anyone used this correction before? Is it effective ie reducing the farfield location by quite a bit?
Thanks |
Vortex in an intake pipe, critical submergence | Julien Pralong | FLOW-3D | 1 | October 23, 2010 15:24 |
creating vortex core line | aay023 | Main CFD Forum | 0 | September 15, 2010 21:49 |
Pressure farfield vs Velocity Inlet BC | DarrenC | FLUENT | 1 | September 16, 2009 02:23 |
turbulent scales of forced vortex and free vortex | lcw | Main CFD Forum | 3 | September 1, 2005 13:40 |
Kármán vortex street in cavitating flow behind bodies in the cavitation tunnel | L. Könözsy | Main CFD Forum | 0 | April 17, 2000 13:16 |
