August 30, 2005, 15:22 |
help! air viscosity versus pressure
Does anybody know the relationship between the air's viscosity and the pressure(0.1 to 10000 times of the atmosphere pressure)? Thanks a lot!!
August 30, 2005, 16:00 |
Re: help! air viscosity versus pressure
1. Link the pressure to the temperature with some classical compressible fluids relations 2. Use the power or Sutherland's law which give the viscosity as a function of the temperature
August 30, 2005, 16:42 |
thank you Buch!I am in the field of electrostatics,and I am working on eletrohydrodynamic flows.In my case the temperature is constant and only the pressure changes.
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
Properties of air versus temperature AND pressure | Vincent | Main CFD Forum | 5 | July 28, 2008 06:28 |
help! air viscosity versus pressure | lin | Fidelity CFD | 2 | November 3, 2005 22:43 |
