SIMPLE
Old   August 31, 2005, 19:34
Default SIMPLE
newcomer_ to_ CFD
I have recently applied Peric's codes to calculate the flow field of a thin channel. The boundary conditions are as follows: 1) west side is an inflow 2) east side is an impermeable wall 3) south side is symmetric plane 4) north side is a porous wall. for the condition 4) the U-velocity is calculated from no-slip condition and V -velocity at the porous wall is calculated from total mass conservation. The solution is calculated from colocated grid.
The SIMPLE scheme does not give me converged solution despite i have changed the under-relaxation factors. Does and of you have any suggestions how i can improve this? Your feedbacks are much appreciated.
thanks! newcomer_ to_ CFD
Old   September 2, 2005, 10:29
Default Re: SIMPLE
George
Hello! For the problem that you have, are you sure that the code calculates the total mass conservation also in the V direction and not only in the U direction. I had a similar problem and only the U velocity was corrected at the outlet (in order to ensure the mass conservation). You should know that these codes are only for incompressible fluid flow. Hope I helped a little bit.
Thread Tools
Trackbacks are On
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 18:02
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver renyun0511 OpenFOAM Running, Solving & CFD 0 November 10, 2010 02:47
Making SIMPLE converge faster Fabio Main CFD Forum 4 April 9, 2006 11:35
PISO vs. SIMPLE benedikt flurl Main CFD Forum 2 April 14, 2005 06:54
flow over a 2D cyl using SIMPLE T Main CFD Forum 1 January 27, 2001 08:32
