someone to answer..Difference between LES and RANS
Old   September 2, 2005, 08:02
Default someone to answer..Difference between LES and RANS
Nik
Hi all, Although I have tried to understand at my own the difference between LES and RANS in layman or simple terms but am unable. I shall be highly grateful if someone can elucidate the basic difference with respect to followings.. a) HOW LES is capturing the unsteadiness of the flow in better terms than RANS? (turbulence modelling and subgrid modelling) b) For a same baseline grid, is LES suppose to give better results for some turbulent flow in near wall region? c) Where is the difference in coding, if i am using flux splitting method for RANS (with KW turbulence model) and want to switch to LES for better flow prediction? Cheers and see ya..
Old   September 4, 2005, 08:38
Default Re: someone to answer..Difference between LES and
D.Pavitran
Hi nik,
I hope that, you can get the answers for your query from the following chalmers weblink.
http://www.tfd.chalmers.se/doct/comp...ure_notes.html
Just click on the topic LES, in this weblink.
regards/ pavitran
Old   September 4, 2005, 11:40
Default with Regards to DES
Endee
Do we use the same equations for DES with only difference of Turbulence model in RANS and Subgrid Scale model in LES domain?
LES vs RANS student2 Main CFD Forum 57 March 3, 2020 09:54
RANS to LES: Flame dissapears?? LB Main CFD Forum 4 September 6, 2007 18:53
Laminar Flamlet RANS to LES LB FLUENT 0 September 5, 2007 05:35
Mapping RANS data onto an LES christian OpenFOAM Running, Solving & CFD 0 April 13, 2007 05:31
RANS results for LES Li Yang Main CFD Forum 5 June 17, 2002 05:34
