Boundary Layer thickness estimation
Old   March 6, 2012, 10:47
Default Boundary Layer thickness estimation
Stephen
moonser is on a distinguished road
Hi guys and ladies.
I have gotten to grips with the meshing in Ansys finally and just need to be able to justify that the mesh is fine enough around the boundary layer. I am doing a VERY simple 2-d circle. I am just not sure how to work out the thickness. I have been told that I can use whatever velocity I want.
Can anyone give me a quick crash course in how to calculate/justify this.
Thanks in advance for any help.
moonser is offline   Reply With Quote
Old   March 6, 2012, 11:12
Andrew
mettler is on a distinguished road
you can calculate the thickness based on your Re. Any fluids book will show you how.
good luck
mettler is offline   Reply With Quote
Old   March 6, 2012, 11:26
Roland Peters
RolandP is on a distinguished road
I'm having a similar issue, and was just wondering if it was ok, as an approximation, to use the Blasius solution for an airfoil? Or is that too inaccurate?
RolandP is offline   Reply With Quote
Old   March 6, 2012, 11:32
Andrew
you just need a good estimation in order to make your grid fine enough to capture it in your CFD analysis.
Old   March 6, 2012, 11:33
Roland Peters
Tidy, I've been going around in circles :s
I'll give it a crack thanks
Old   March 6, 2012, 11:38
Stephen
Cheers very much mate. Wasn't sure that you were aloud do that I thought I was missing a geometry factor somewhere.
Old   March 6, 2012, 16:26
Administrator
pete's Avatar
Peter Jones
pete will become famous soon enough
Check out http://www.cfd-online.com/Tools/yplus.php
pete is offline   Reply With Quote
Old   March 7, 2012, 05:51
panospap is on a distinguished road
Depending on your Re (flow material, characteristic length, velocity), you will have to use a specific thickness for your first cell to achieve a desired y+ value. For high Re you have to define very small thickness for the first cell. If you have been told you can use any velocity you want, then I would advise to run the calculation for low velocity, where you can have a good result for not so fine mesh.
The desired value of y+ depends on the turbulence model you are using. For example, for SST model y+ value should be around 1-2.
The tool given above gives you an easy way to determine all these. The only thing is that in this tool you also have to specify the boundary layer length, which is not easy to be determined in all applications.
I hope that helps.
Panos
panospap is offline   Reply With Quote
Old   March 7, 2012, 06:35
Default Check your yplus value
cdf_user is on a distinguished road
Your yplus value has to be less than 2 in order to accuratly represent the boundary layer. If it is more than two, refine your mesh.
cdf_user is offline   Reply With Quote
Old   May 30, 2012, 02:02
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
I am also confused about the boundary layer length. Is there anyone could show me the way to determine it?
rikio is offline   Reply With Quote
Old   May 30, 2012, 11:03
Boundary Layer length is function of Reynolds number. The exact for formula is in introductory fluid mechanics books. It is something like a*(Re^b).
Thread Tools
Trackbacks are On
No layers in a small gap bobburnquist OpenFOAM Native Meshers: snappyHexMesh and Others 6 August 26, 2015 09:38
Boundary layer thickness calculation nat FLUENT 0 April 9, 2009 06:04
plotting boundary layer thickness graphs in a 3d Neelima FLUENT 1 March 29, 2006 18:04
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
boundary layer thickness 98.4F Main CFD Forum 1 December 29, 2000 08:23
