July 13, 1999, 16:23 |
CFD of tilting disk check valve
Does anyone know of any CFD consulting firms that can model a tilting disk check valve with the following parameters?
24" Crane 5° tilting disk check valve Flowrates will range from 100 gpm to 12000 gpm I have talked with Fluent and they said that they had a Beta test version of their code that would combine the fluids and structures components, but are not sure of the accuracy yet.. Note: Structures are required since part of the problem is to determine the disk position and if the disk flutters at the low flows. |
July 13, 1999, 17:07 |
Re: CFD of tilting disk check valve
CFD Research Corporation (CFDRC) provides software and consulting services for CFD. We have a fully functional code (CFD-ACE+) to do coupled fluid-structure interaction problems. It is also being currently used by our clients for such applications.
Please visit our home on the web http://www.cfdrc.com. Please contact Mr. Fritz Owen (sfo@cfdrc.com; 256 726-4827) to get more information on consulting services we provide. |
ASME CFD Symposium | Chris Kleijn | Main CFD Forum | 0 | August 22, 2001 06:41 |
CFD Symposium (Call for Papers) | Chris R. Kleijn | Main CFD Forum | 0 | October 5, 1998 10:25 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 8, 1998 08:19 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 3, 1998 08:45 |
salary range | Frank Muldoon | Main CFD Forum | 7 | August 3, 1998 19:04 |
