March 10, 2012, 01:34 |
What is the normal viscous force(stress)?
Rep Power: 14 |
I understand the tangential shear stresses (or forces) acting on a fluid element due to friction between moving fluid layers, but I can't imagine how viscosity might cause a normal force (on a fluid element), Doesn't it always have a tangential effect? .... explain please! |
March 11, 2012, 14:20 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
March 12, 2012, 21:07 |
Rep Power: 14 |
I think gradients are harder to picture in the normal direction because we can really only experience a sliding type of friction when we a moving tangential to a surface, we can't really have a normal gradient in velocity because we are solids. It might help to imagine the friction in a tangential shear stress and rotate it into a normal stress. You still have particles sliding past each other just in a different and harder to understand way. You can also relate it to the diffusion of momentum in analogy with heat and mass transfer starting from ideal gas theory but that's a bit complicated to.
How to get normal vector to the face? | Viatcheslav Kulikov | FLUENT | 1 | August 31, 2017 03:03 |
Normal vector, slope and aspect angle | g_niro | Main CFD Forum | 0 | February 2, 2011 17:24 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
Normal stress?/ | bowlderyu | Main CFD Forum | 1 | October 28, 2008 21:57 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
