How to correct the expression given below
Old   March 13, 2012, 05:16
Question How to correct the expression given below
baburaj m
baburaj is on a distinguished road
mw= 0.05585 [kg mol^-1]
Density= 7860 [kg m^-3]
z= 2
F= 96500 [A s mol^-1]
Expression 2 = (mw*Current Density@brine bottom*ctstep)/(Density*z*F)
This expression is showing error while executing.
WARNING
Syntax error detected in the expression assigned to 'Expression 2'.
Successfully read 3 characters:
mw
then error detected at:
= 0.05585 Density = 7860 z = 2F= 96500 [A s mol^-1]Expression 2 = (mw*Current Density@brine bottom*ctstep)/(Density*z*F)
Details - Unexpected character.what is wrong with this
baburaj is offline   Reply With Quote
Old   March 13, 2012, 07:32
Andrew
mettler is on a distinguished road
I am going to take a guess and say that it does not know what "Current Density@brine bottom*ctstep" means.. Have you tried eliminating things in expression 2 to see if you can get it to work - start with one variable and keep adding one until you get an error
mettler is offline   Reply With Quote
Problem About Running Fluent In Linux mitra FLUENT 18 June 20, 2019 02:11
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 17:23
