Test cases of different levels of complexity
Old   September 15, 2005, 00:03
Default Test cases of different levels of complexity
quarkz
My aim is to simulate the flow past an airfoil. I'm now trying to test my structured FVM code for any errors.
Initially, I wrote a cartesian code and used the well known lid driven cavity. I then moved on to write the structured code and I've used a skewed lid driven cavity test by Erturk (www.cavityflow.com).
Both worked well. Should I go on directly to simulate an airfoil? Or are there any test cases which I can do before going to the airfoil problem?
Thanks
Old   September 15, 2005, 18:47
Default Re: Test cases of different levels of complexity
Scott Shaw
You don't say whether your code is inviscid/viscous compressible/incompressible.
You should try to run the code for some benchmark cases (cases for which you can obtain analytic or semi-analytic results). Examples include; compression over a wedge, expansion over a backwards facing wedge; williams airfoil and williams multi-element airfoil; laminar flow over flat plate; turbulent flow over flat plate. The NPARC V&V website is a good place to start for more details/data.
Scott
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Test Cases tstorm FLUENT 1 May 27, 2009 03:41
test cases Maciej Matyka Main CFD Forum 3 November 24, 2004 08:27
