Vorticity Equation when nu is not a constant
Folks:
I am interested in deriving the Vorticity equation in Cylindrical Coordinates (r,theta,z) with Theta symmetry and u_theta = 0. The main problem is the viscosity cannot be treated as a constant but varies spatially. For a constant viscosity we get the simple equation, dw/dt + u.Del(w) = nu Del^2(w) where u = {u_r,0,u_z} and w = vorticity = {0,w,0}, where w = du_r/dz - du_z/dr. I am interested in a similar vector equation when nu is not a constant. Could some one please help me or let me know where I can find it. Thanks. Sam |
Re: Vorticity Equation when nu is not a constant
You can start with the general Navier-Stokes equations, take the curl, and then do a "simplification" in the cylinderical coordinate system! This is a simple exercise in math.
Note that your question is vague. A variable nu could imply variable density only, variable viscosity only, or variable viscosity and density. Either way, you're going to end up with quite a bit more terms than for the constant nu case Adrin Gharakhani |
