SIMPLE-M method
Old   October 2, 1998, 16:07
Default SIMPLE-M method
Chuck Leakeas
Has anyone used the SIMPLE-M (or SIMPLEM Modified) method? It is similar to Patankar's SIMPLE and SIMPLER method only does not use a pressure correction equation to correct the pressure field, it solves for the pressure directly from the pressure equation which is derived from the continuity and momentum equations. Has anyone done compressible flows with any of these methods? If you have some knowledge about these methods please contact me and we can discuss the details.
SIMPLE family and Fractional Step Method Geon-Hong Main CFD Forum 2 April 5, 2010 18:05
SIMPLE method for inviscid flow abcdef123 Main CFD Forum 0 February 26, 2010 08:24
Apply Multigrid method to SIMPLE Algorithm yang Main CFD Forum 1 February 25, 2006 11:28
need help in fotran code for simple method saritha Main CFD Forum 3 April 30, 2004 12:55
SIMPLE method for compressible flow in pipe Reza Main CFD Forum 0 August 27, 2002 22:43
