Which Code is Best for Two Phase, Heat Transfer |
September 23, 2005, 20:26 |
I'm currently in the process of evaluating both the Fluent and CFX codes. The code that will be selected will be used for both turbomachinery and heat transfer simulations. I've used both codes in the past for turbomachinery; however, from a heat transfer standpoint I'm a novice. The heat transfer problem that I'm most interested in solving relates to flooded evaporater using R134a. Which code, if any, can handle this type of two phase, heat transfer problem where 100% of the liquid refrigerant entering the vessel is converted into gas leaving the vessel. Any help would be appreciated.
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
heat transfer in discrete phase model | halavikia | FLUENT | 1 | March 15, 2011 20:58 |
About phase change heat and mass transfer | Michael | FLUENT | 2 | February 13, 2011 01:49 |
