September 19, 2005, 06:35 |
Tecplot file converter for Paraview/OpenDX
Does anyone know if there is conversion utility that will convert Tecplot file format (specifically tecplot_ise) to import easily into OpenDX or Paraview?
Mason |
September 19, 2005, 09:37 |
Re: Tecplot file converter for Paraview/OpenDX
I know that I'll answer with a stupid question, but
Do you have Ensight? With Ensight you'll be able to open your Tecplot file and export Ensight case to read with Paraview. Regards. Renato N. Elias |
September 19, 2005, 12:25 |
No, I don't have Ensight. Is it open source? I will check this out although the .dat files that are created from DESSIS are not standard Tecplot files at all (they have a OEM relationship). Thanks for the hint though Renato.
Mason |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 04:43 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
