September 27, 2005, 09:01 |
contact discontinuity
does anyone know which method can best handle contact discontinuity?
thanks. |
September 27, 2005, 22:39 |
Re: contact discontinuity
Flux difference splitting (FDS) schemes like those of Roe are better at contacts. Flux vector splitting schemes generally do a poor job but AUSM family is probably as good as a FDS scheme.
September 28, 2005, 03:38 |
You may also wish to look at schemes such as Toro's WAF method and HLLC. Toro's book (has Riemann solvers in the title - do a search on amazon) is a *very* good starting point if you need more info/background.
Scott |
September 29, 2005, 21:28 |
HLLC scheme and PPM scheme are also capabile of dealing with contact discontinities, and PPM scheme is more accurate.
September 30, 2005, 09:17 |
thank you all for the info.
Dynamic contact angle | rmousavibt | Fluent UDF and Scheme Programming | 12 | October 31, 2021 22:38 |
help with UDF for contact angle based on contact line velocity | gandesk | Fluent UDF and Scheme Programming | 14 | October 29, 2012 13:58 |
Ansys Workbench contact problem! | JoelHenrik | ANSYS | 1 | October 1, 2010 14:57 |
Theoretical background of formula for dynamic contact angle in interfoam | sebastian_vogl | OpenFOAM Running, Solving & CFD | 3 | June 22, 2009 12:25 |
Solid-Solid Heat Transfer with Contact Discontinuity | Jonas Larsson | Main CFD Forum | 9 | September 10, 1999 15:46 |
