Lift and Drag
Old   April 6, 2012, 00:02
Default Lift and Drag
David
bagofmilk is on a distinguished road
I'm new to CFD. I modeled a frisbee in SolidWorks and used Flow Simulation. I was wondering what your thoughts were on the better frisbee (see images attached). I know the ideal situation is to have a high ratio of Lift to Drag forces. It seems that FRISBEE B accomplishes that, but I'm wondering if it is likely to be more unstable during flight.
Any input is greatly appreciated.
FRISBEE - A
FRISBEE - B
bagofmilk is offline   Reply With Quote
Old   April 6, 2012, 05:21
truffaldino's Avatar
truffaldino is on a distinguished road
Check pitching moments relatively the center of gravity. The configuration with smaller pitching moment will be likely more stable.
truffaldino is offline   Reply With Quote
Old   April 6, 2012, 09:05
David
So I've found that Pitching Moment is defined by a product of:
Cm [Coefficient of Pitch Moment] x 1/2 x (fluid density) x (velocity^2) x (cross-sectional area) x (disc diameter).
is Cm a function of the physical aspects of the frisbee? If not, can't I assume Cm to be equivalent between the two? (Obviously the two pics shown have identical initial conditions and boundary conditions.)
If it is a function of the physical aspects, what factors do I need to look into? Can I use SolidWorks or Flow Simulation to help me determine any of these coefficients?
Thanks!
-David
Old   April 6, 2012, 11:20
Hello David,
Cm depends on the object shape, orientation (angle of attack) and reynolds number (speed). I have never worked with SolidWorks or Flow Simulation, but any serious CFD software should give force moments relatively a user defined axe as an output option.
Usually analysys of low-speed flows is a challenge due to considerable influence of the flow separation and turbulence modelling on the Drag and Lift. I do not know if SolidWorks is reliable enough for this kind of simulations: it seems that the turbulence modelling is a weak point of this software.
Truffaldino
P.S. you can take a look at this thesis:
http://biosport.ucdavis.edu/research...mmelThesis.pdf
Old   April 6, 2012, 17:41
David
Thanks! This is great info
Old   April 6, 2012, 17:46
Thumbs up
David
I was able to find out that SolidWorks Flow Simulation can find the Center of Pressure and force moments by setting a torque "goal" equal to 0. But this thesis has some great background info.
Thread Tools
Trackbacks are On
How does FLUENT calculate lift and drag? xTamx420 FLUENT 0 May 30, 2011 13:35
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 10:38
Lift and Drag ??? Yogibear STAR-CCM+ 4 June 20, 2010 10:11
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 27, 2007 23:38
drag and lift coefficient Noé CD-adapco 5 July 13, 2004 10:21
