2D Riemann problem
Old   September 29, 2005, 01:50
Default 2D Riemann problem
ganesh
Dear Friends,
Can anyone suggest the boundary conditions for 2D riemann problems? For a specific configuration wherein 4 shocks appear and interact, I get the shock curving at the boundary, while I have seen that in many simulations by others the shock is normal at the boundary.
Regards,
Ganesh
Old   September 29, 2005, 08:53
Default Re: 2D Riemann problem
Scott Shaw
By boundary do you mean a wall ? If so you should treat it in the same way as you treat sub-sonic inflow or sub-sonic outflow conditions. This is because the component of velocity normal to the wall is zero (no penetration condition). I prefer to treat it as outflow as I then only have to specify one condition (U=0).
Scott
Old   September 29, 2005, 23:14
Praveen. C
The boundary in this case is an artificial boundary meant to truncate the computational domain. There is no rigorous way of deriving such boundary conditions. What most people do is to extrapolate from inside the computational domain. You may have to limit the extrapolated values if there are shocks nearby.
Old   September 30, 2005, 13:53
ganesh
Dear Friends,
I am in fact using extrapolation from the interior with limiting for shocks. The problem does not arise if the initial conditions are such that either one of the velocity components u or v is zero or both are zero in the four quadrants. ( Actually in this case, the normal velocity on the boundary actually vanishes and this makes things easy). However, when one of the quadrants does have a non-zero u and v, then I experience the problem of shock being not normal to the boundary. I have seen people using theextrapolation bc, but they seem to get normality at the boundary.
Any suggestions ?
Regards,
Ganesh
Old   October 1, 2005, 02:38
Praveen. C
You could try a Neumann-type boundary condition,
du/dn = 0
for all the flow quantities. Or you could do a constrained least squares interpolation, ie., fit a polynomial such that the Neumann condition is satisfied either exactly or in a least-squares sense (penalty function approach).
Old   October 3, 2005, 02:33
ganesh
Dear Praveen,
Thankyou for the suggestion on VN boundary condition, it does work. However, what I had to do was to revert to first order accuracy(constant poly. recons.) ie U_boundary = U_(cell centoid of the cell sharing the boundary face). I was wondering if I could do the same with second -order accuacy. Least squares is a possibility, but will it wok effectively ?
Regards,
Ganesh
Old   October 3, 2005, 04:40
Praveen. C
You can try to interpolate to the cell face by satisfying Neumann bc and then compute the flux using the interpolated values. Of course this will be extra work since you have to define a stencil for the cell face. You may have to limit the interpolated values especially if there are shocks. I have used a min-max type of limiting in such situations, ie., if the interpolate exceeds the interval {min, max} then chop it to the end-point of the interval. Its not a nice way to solve but it works.
PS: If you are in IISc, Bangalore, you can talk to Keshav Malagi who has recently solved 2D Riemann problem.
Old   October 3, 2005, 05:55
ganesh
Dear Praveen,
Thanks for the suggestions. I am in IISc and I shall talk to Keshav regarding the 2D Reimann problem.
Regards,
Ganesh
Old   October 3, 2005, 07:58
Default Re: Keshav Malagi
rmi
Praveen,
Am interested Keshav Malagi work. can you introduce his URL or his department......i really need to get in touch with him.
Thanks.
Old   October 3, 2005, 08:09
A.S.
Ganesh,
I came across a report for boundary conditions. You can email me at shukla_apoorv1975@yahoo.co.uk. I have to did it up and will forward it to you. Hope it helps.
Regards
A.S.
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
Reimann problem Shuo Main CFD Forum 5 May 28, 2007 15:44
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
