Problem with SOR
Old   October 1, 2005, 03:26
Default Problem with SOR
Davoche
hi everybody, I have a big problem with a SOR method applied to an elliptic equation.
In regular mesh, it works very well ( convergence and results ok ) , but as soon as I use an irregular mesh ( even if it is very smooth ), my convergence rate stops at a value and stay constant.
Is it a normal behaviour for a finite difference scheme ? I precise that I use periodic Boundary conditions in 2 directions and Neumann in another ( So I'm 3D )
Thanks
Old   October 1, 2005, 21:35
Default Re: Problem with SOR
agg
It is possible that convergence rate drops. There are solutions however to that for example, preconditioning. There are several fast packages available for elliptic equations like FISHPACK and MUDPACK, if you do not have to stick to SOR methods
Old   October 2, 2005, 03:33
Davoche
Thanks but I want to use this SOR as the core of my Multigrid.
If it doesn't work ( not converge precisely )only with Sor, it shouldn't with Multigrid, isn't it ?
The result of SOR for irregular mesh is not wrong, but not enough accurate.I need a precision of 1.E-13 ( divergence free ) an I obtain only 10E-2
Old   October 3, 2005, 10:23
Davoche
With Dirichlet Boundary Conditions, all is Ok ( on regular and irregular mesh ). But for Neumann, the result is not accurate especially where the mesh is the finest. ( I precise it is the same mesh than for Dirichlet test ).
So, I don't understand why the result is such affected with Neumann BC ?
Old   October 3, 2005, 11:01
agg
How did you implement Neumann BC in your code? Do you use a central differencing method or something else?
Old   October 3, 2005, 11:50
Davoche
Hi Agg, My Neumann is implemented with second order difference scheme with quantities at the cell center, for exemple in 1D regular mesh:
On boundary, T_{i=wall-1/2}=T_{i=wall+1/2} ( with T_{i=wall-1/2} is a ghost symetrical node ), with this I have a zero gradient on the wall.
In SOR : I replace it directly so
Sourceterm_{i=wall+1/2}=1/(dx^2).(T_{i=wall+3/2}-2.T_{i=wall+1/2}+T_{i=wall-1/2}) becomes
Sourceterm_{i=wall+1/2}=1/(dx^2).(T_{i=wall+3/2}-T_{i=wall+1/2}) only for the point near the boundary.
Old   October 3, 2005, 14:02
agg
Your implementation seems to be correct. So, here is another theory.
1) When you use a Neumann bc (at all boundaries), infinite solutions exist for the dependent variable. For example, a solution T1=10; T2=10; T3=10 will satisfy dt/dx=0 at node 2. Similarly T1=11; T2=11; T3=11 will also satisfy your bc. It is possoble that your SOR solver keeps bouncing between these infinite solutions.
However, when you have a dirichlet bc, the solution has to relax to the prescribed value at the boundary (say T=0) and the SOR solver behaves nicely, since only ONE solution will satisfy the bc.
What you can try is: Try a combination of Neumann and dirichlet bc and see how your solution behaves. If it behaves nicely, just like when you have dirichlet bc's at all boundaries, then the problem that i illustrated above might be the one holding up your SOR solver.
Just a theory! and i hope i haven't caused any confusion.
Old   October 4, 2005, 03:18
Davoche
Thanks for your suggestion Agg,
I've try it and it converge very very slowly now ( but the result is still the same ).
In fact, as my code works well in regular mesh ( even for different size of channel ) , I don't think it is due to a problem of bouncing between solutions.
It is clearly due to the staggered mesh... In fact, as soon as I use a staggered mesh, I see that the solution of my elliptic equation is the most diverging from the theoritical result at the location of the finest mesh of my grid ( I precise I am in Double precision ) .
But I don't know why...
Old   October 4, 2005, 10:33
agg
ok. Do you use under/over relaxation? Maybe you should play around with those parameters and see if that helps.
Old   October 4, 2005, 11:59
Davoche
Thank one more time, but I have already checked it.
Thread Tools
Trackbacks are On
engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 08:45
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
