-   -   Published Axial Fan Data (http://www.cfd-online.com/Forums/main/999-published-axial-fan-data.html)
Vincent Johnston July 12, 1999 16:26
I am looking for reliable, experimental in-line axial fan data that has 3-D velocity vector information both upstream and downstream of the fan, in high and low blockage configurations.
Has anybody come across this information?
Sergei Chernyshenko July 12, 1999 16:30
Re: Published Axial Fan Data
Hi.
I am not sure, but look at http://www.egi.kth.se/ekv/stcf/index.htm
There were some data on turbomachinery flows there. Not exactly fans, I am afraid.
Good luck.
Sergei
John C. Chien July 14, 1999 00:49
(1). Fan and motor are normally tested together in the test cell to provide the performance data, in terms of RPM, flow rate and pressure difference. (2). Measurement of 3-D velocity vector distributions upstream and downstream are not required. The actual flow field is a function of fan installation ( and fan blade design) . (3). Measurement of the Velocity field should not be a difficult task.
