Published Axial Fan Data
Old   July 12, 1999, 16:26
Default Published Axial Fan Data
Vincent Johnston
I am looking for reliable, experimental in-line axial fan data that has 3-D velocity vector information both upstream and downstream of the fan, in high and low blockage configurations.
Has anybody come across this information?
Old   July 12, 1999, 16:30
Default Re: Published Axial Fan Data
Sergei Chernyshenko
Hi.
I am not sure, but look at http://www.egi.kth.se/ekv/stcf/index.htm
There were some data on turbomachinery flows there. Not exactly fans, I am afraid.
Good luck.
Sergei
Old   July 14, 1999, 00:49
John C. Chien
(1). Fan and motor are normally tested together in the test cell to provide the performance data, in terms of RPM, flow rate and pressure difference. (2). Measurement of 3-D velocity vector distributions upstream and downstream are not required. The actual flow field is a function of fan installation ( and fan blade design) . (3). Measurement of the Velocity field should not be a difficult task.
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
urgent pressure condition for axial flow fan VIPUL FLUENT 0 October 24, 2008 02:01
Fluent 2D Model - Axial Fan in a Duct J FLUENT 0 April 18, 2006 02:25
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
axial flow in counter rotating ducted fan Vishu FLUENT 4 January 13, 2004 17:52
