Home > Forums > Special Topics > Mesh Generation & Pre-Processing
general rule of thumb for bi-exponential meshing
Like Tree2Likes
  • 2 Post By flotus1
Old   February 7, 2013, 15:15
Default general rule of thumb for bi-exponential meshing
Kyle
hippiekyle is on a distinguished road
I'm fairly new to this, so pardon if I say something stupid.
I'm creating a 3d mesh in gambit for a lid-driven cavity flow. The cavity is 1:1:3 with Re~ 10,000 and we'll be using RANS (probably Fluent, maybe openfoam) to run cases.
I created the geometry and mesh, but I have no idea what number to use for bi-exponential meshing. Another student mentioned using 1.05 in his research, but that seems too sparse in some parts in the middle. I tried 0.7, but I wanna make sure and have sufficient resolution near the walls. I honestly don't know even a typical range for this, and I'm only guessing on what's too coarse or fine, since I've never made my own grid before.
I realize there's no exact answer or whatever, I just want a general guide.
hippiekyle is offline   Reply With Quote
Old   February 11, 2013, 03:44
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
The most general rule of thumb is that the mesh has to be finer close to the walls. Consequently, only values greater than 1 make sense here.
Now the second constraint is that the growth rate should not be too high because of accuracy issues, most often values below 1.05 are considered ok.
The third (and most important) constraint is the height of the first at the wall. Depending on the type of wall modeling you use, the dimensionless wall distance Y+ has to be kept within a specific range. You might want to run a simulation, evaluate Y+, and change the mesh accordingly.
Now if you consider the mesh to be too coarse in the middle with the first cell height chosen to match Y+: choose a lower growth factor, because in general:
low growth rate -> high accuracy
hippiekyle and Appleologe like this.
flotus1 is offline   Reply With Quote
cavity flow, gambit, mesh and grid
[swak4Foam] Installing swak4Foam to OpenFOAM in mac Kaquesang OpenFOAM Community Contributions 22 January 21, 2013 11:51
Rule of Thumb to Estimate Total Cells chinc Main CFD Forum 0 April 12, 2011 21:52
Question on Basic Meshing Rule Huygen Main CFD Forum 0 January 15, 2009 12:20
RPM (+/-) thumb rule studentCFD CFX 1 November 6, 2007 05:19
meshing rule Dimitris Tavernarakis Main CFD Forum 1 May 16, 2001 14:34
