Airfoil Meshing software
Hey ppl,
which is the best software to create a structure mesh for an un-symmetric airfoil 2D and 3D, and how long will it take to make a good one with very less skewness i will be running my cases in OpenFOAM thanks, Hasan. |
I am working on axial flow fan, it is twisted blade. I am using Gambit, it is bit easy comparing with other software, but it is not a good choice. If you are in the begging stage better to go for ANSA or ICEM-CFD. ICEM will be nice, but some utilities are really terrible (face with face trimming), it is very simple in Gambit. Since you are going to use OpenFOAM, better to stick with ANSA (ßCAE) and it produces direct OpenFoam Mesh. My personal opinion is, ANSA will be the best choice for OpenFOAM users. the license is bit cheaper than other software. Thanks, Sivakumar |
Salome
one of my friends have used salome 6.5 for meshing his airfoil last year and it was good he had great control over the mesh..!!! but i was still thinking if anything better was available..:)
i have used salome aswell for someother diff geometry but i was seeing if there is any softwares that u mentioned specialises on airfoil meshing as airfoil is one very common object to be calculated using CFD :D |
1 Attachment(s)
Please have a look at GridPro. You can create the highest quality meshes and it is free for academic use with a limited number of blocks.
I have two ready to run GridPro setups for NACA 0012 and NACA 0025 on my homepage. http://www.beilke-cfd.de/naca0012_gridpro.tar http://www.beilke-cfd.de/naca0025.tar Here is an example of the 0012 case for those having ccm+: http://www.beilke-cfd.de/naca_0012_5_degree.sim.gz |
You can also get templates for aerofoils from GridPro by mailing to gridpro@gridpro.com .
:D
@sam .. thanks a lot for sharing :) .. .ill spend some time on grid pro and see where it takes me :) :)
I am using Pointwise,and it really creates a good grid.Moreover,its simple to use.
nice meshes @ Gridpro.
| All times are GMT -4. The time now is 08:49. |
