May 29, 2013, 05:46 |
Salome 3D Mesh generation
maria grazia
Rep Power: 12 |
Hi, I'm working on a complex shape and i need to generate a 3D Mesh of this element, that is a cylinder with some cuts inside. I used the software Salome to create this geometry, but when I try to generate the 3D Mesh of this element I only can generate it with a too high dimention of cells. The algorithm I used are:
3D: Tetrahedron (Netgen) --> Hypothesis:Max element volume 8 2D: Triangle (Mefisto) --> Hypothesis:Max element area 8 1D: Wire discretisation --> Hypothesis:Local length 3 But these dimentions are still too big for my mesh. When i try to set smaller values Salome gives an error and generates the Mesh only on the surfaces. The error is: Exception in netgen::OCCGenerateMesh() at Volume meshing I would need to set local length = 2 or =1 Can anybody help me with this? I attached the file with my geometry here! Thank you so much in advance! Mary |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[ICEM] Need urgent help for hybrid mesh generation | Pursuor | ANSYS Meshing & Geometry | 1 | August 29, 2012 16:04 |
[ICEM] Mesh generation | bobinson | ANSYS Meshing & Geometry | 2 | August 17, 2012 13:23 |
checkMesh and decomposePar crashes with salome IDEAS mesh | pajofego | OpenFOAM | 0 | June 23, 2011 08:43 |
General questions on grid-based computing | Adrin Gharakhani | Main CFD Forum | 21 | June 5, 2000 13:47 |
