Home > Forums > Special Topics > Mesh Generation & Pre-Processing
how can i use a set of node points
Old   December 7, 2013, 10:02
Default how can i use a set of node points
rafMudaf is on a distinguished road
I have a 2D triangular mesh generator that takes in a 2d image with an object of interest inside (like an airfoil or profile of a car) and outputs x and y coordinates for all of the node points. It can also output the three vertices for each triangle. Aside from a plot of these coordinates connected with lines, that's all I have for a mesh. There is a defined rectangle around the object in the image which could serve as boundaries.
Is there any way I can import that to a mesh generation software that will allow me to apply boundary conditions and output something useful to a solver like fluent or OpenFOAM?
rafMudaf is offline   Reply With Quote
Old   December 9, 2013, 17:25
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
If you have the locations of the nodes and the connectivity of the triangle, it will be fairly easy to write a small code to create a file that can be read by Fluent for example. You can find a description of the Fluent .msh format online to guide you.
cdegroot is offline   Reply With Quote
How set experimental points values as wind tunnel boundary conditions vidade FLUENT 3 December 23, 2012 16:02
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 04:31
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
how to set velocity on node tipakorn Siemens 3 January 23, 2008 05:05
