Home > Forums > Special Topics > Mesh Generation & Pre-Processing
meshing problem with some complicated geometry
Old   December 27, 2013, 07:42
Default meshing problem with some complicated geometry
Parth Panchal
Parth320 is on a distinguished road
sir,
i have to work with cfd fluent. before that as a part of pre processing i need to mesh tha geometry. My geometry is assembled with 15 components. So basically its a very complicated geometry. I need to work for heat transfer analysis of that geometry. please suggest some capable software that can sucessfully and easily mesh the assembly.
if anybody is having mastery in meshing, please let me know.
thanking you...
Parth320 is offline   Reply With Quote
Old   February 6, 2014, 23:13
Ramjan
Ramjan is on a distinguished road
hopefully its same geometry which i replied sometime back
Please share the geometry, I will help you
Ramjan is offline   Reply With Quote
[DesignModeler] Fill tool - grouping the faces of a complicated geometry? HeikkiT ANSYS Meshing & Geometry 8 July 20, 2016 07:37
[ICEM] Meshing a pipe geometry selvam2487 ANSYS Meshing & Geometry 4 September 2, 2013 12:47
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Problem meshing turb. blade tip clearance geometry Balu FLUENT 0 June 7, 2008 21:10
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
