Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Unstructured Hybrid Mesh Density ICEM
Old   March 31, 2016, 14:46
Default Unstructured Hybrid Mesh Density ICEM
Matteo
fomalhaut is on a distinguished road
Hi, I need to use unstructured mesh in a portion of the Leading Edge of a compressor blade cascade. I used a free block, imposing only tetra inside. The problem is that close to the leading edge, the elements grow up, without keeping the height of the structured mesh (calculated to meet the y+ requirement).
Ho can I do to have a similar distribution to the structured mesh?
I enclose 2 snaps of the area.
fomalhaut is offline   Reply With Quote
Old   April 3, 2016, 08:50
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
Is it possible in ICEM to use inflation layers in unstructured meshes, too? If so, you should use inflation layers with the same number of cells and the same clustering as in the blocks with the structured mesh. Then you fulfill the y+ requirements in the structured and unstructured blocks and resolve the boundary layer flow with the same accuracy.
DarylMusashi is offline   Reply With Quote
[ANSYS Meshing] High quality unstructured hybrid mesh around ship flinde ANSYS Meshing & Geometry 2 March 3, 2015 18:04
[ANSYS Meshing] Hybrid mesh in ICEM mohammad ANSYS Meshing & Geometry 0 March 13, 2014 13:42
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre powpow CFX 3 December 20, 2012 09:14
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts a.habibi ANSYS Meshing & Geometry 5 October 4, 2012 05:10
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
