March 5, 2013, 11:08 |
help with fine/marine!
I am using fine/marine with a planing hull, and the results are not very accurate,I am wondering is it because the froud number is over 3 or still problems with the meshing?
March 10, 2013, 09:45 |
Romain
You mean the predicted drag is off ? You might want to increase the y+ value, and already prescribe your final trim value in Hexpress.
March 12, 2013, 10:59 |
you mean fix the trim? but what if i don‘t know the final trim?
March 12, 2013, 12:05 |
Romain
Well you could use the trim value you got with your first run, even if forces were off, rotate your geometry in Hexpress and build the mesh.
You can also predict your final trim value with Savitsky's formulae. |
June 16, 2013, 12:36 |
KHB
have you make sure there is no air entrapment below?
This I found to reduce the viscous drag significantly. Check your mesh resolution on the transom as well, it needs to be fine enough so that the water separate from the hull nicely. |
Weighted Deformation Mesh technique in Fine/Marine | naimishharpal | Fidelity CFD | 8 | December 11, 2010 18:03 |
FINE/MARINE | Fred | Fidelity CFD | 1 | February 28, 2007 18:18 |
